Zero times 60 equals 60?
  • May 31, 2022 3:05 PM UTC
  • 79 views
louielou1234
Forum|alt.badge.img+5
Hi There, I am reading from a csv column in which the hours and minutes are spelled out as a string, and I want to calculate the total minutes value. So I created a series of new columns in Attribute Manger and used some Regular expressions to isolate the components of the string. However, when I use the Multiply function against a zero value in the string, I do not get zero. And as we all know zero times any number should always equal zero. Any ideas what I am doing wrong? (I have attached my workbench for reference). THANK YOU!
Best answer by dustin
It's not that it's multiplying by 0, it's that some of your 'B' attributes do not have values. I would setup a conditional value for the 'C' attribute that looks like this screenshot. OR, you could use this expression which will return <null> for the entries without hours: @Evaluate(@Value(B)*60)image
dustin
Forum|alt.badge.img+36
  • May 31, 2022 4:13 PM UTC
louielou1234
  • Jun 2, 2022 2:43 PM UTC
Yes, that absolutely worked. Thank you so much!
