XY point to point distance
  • Nov 23, 2020 1:38 PM UTC
  • 97 views
I think I read entire forum... but can't find any answer.
I have number of single control point, ascii with XY column and corresponding another file containing also XY.
I would like to 1st
  • for each control points from set 1 find a closest point from set 2 and calculate average xy and rms
  • combine the rms and average magnited and output as a one number
Maaaasive thanks for all your time
j
davtorgh
Forum|alt.badge.img+12
  • Nov 23, 2020 5:43 PM UTC
Hi @joolek.o​ ,
I think the following method should do the work you need to find closest points and medium points beetween them:
  1. create points from coordinate attributes (VertexCreator);
  2. reproject to a coordinate system that uses meters as unit measure (Reprojector, better work in meters than degrees);
  3. find the closest points (NeighborFinder);
  4. build lines beetween points (VertexCreator);
  5. cut these lines in the middle (Snipper).
Coordinate 1 of features that come out from the Snipper is the middle point of the line.
screenshot.1screenshot.2
Hope that helps!
fdw
Forum|alt.badge.img+7
  • Nov 24, 2020 11:30 AM UTC
Hi @joolek.o​ ,
Hope that helps!
If you also set the snipper 'Starting Location' to 50 then it wil output a single point in the middle straightaway
davtorgh
  • Nov 24, 2020 1:35 PM UTC
Thank you for the suggestion, fdw.
