Workspace App "calling machine" details
  • Sep 25, 2023 2:26 PM UTC
  • 56 views
pmcpherson
Forum|alt.badge.img+11
Should it be possible to determine the details of the user or machine that "called" a workspace app shared by a URL link? Currently I'm seeing the name of the "owner" under the "RAN BY" column, but I'm interested in learning more details about the user or machine that made the call.
churchfraser
Forum|alt.badge.img+5
  • Sep 27, 2023 11:43 PM UTC
If authentication is required to use a server app, the username will be output as the --FME_SERVER_RUNTIME_USER parameter. I believe if authentication isn't required, the owner of the workspace or automation is inserted as that value.
pmcpherson
  • Sep 29, 2023 11:18 AM UTC
@churchfraser​, thanks for the response. Maybe I will try changing the app to require authorization, although it has been convenient to avoid that requirement.
