WMS Clipped to JPEG
  • Aug 19, 2021 5:50 AM UTC
  • 5 replies
  • 163 views
pauledrummond
Hi. I have a WMS service (Aerial) I would like to consume and clip to a JPEG or similar. Is this possible and if so, what transformers would I need to use?
When I open the WMS I currently get an error...
|ERROR |<WMS> Exception detected for the GetMap operation, requested Content-Type, 'image/png', returned Content-Type, 'text/html'.
Eventually, I want to add this to a dwg output.
Any help would be appreciated.
Regards, Paul
Best answer by redgeographics
You could use a FeatureReader, if you enter the JPG (or the bounding box of the JPG, e.g. through a BoundingBoxReplacer) as the initiator and set the spatial filter to Bounding Boxes Intersect it'll use that bounding box to clip the data out of the WMS.
Forum|alt.badge.img+63
pauledrummond
  • Aug 19, 2021 10:41 PM UTC
Thanks for your response. Your suggestion is exactly the way I wanted to do it.
It seems though I always get returned to the underlying error
I may have to log a support case to find out about that.
Cheers. Paul
caracadrian
Forum|alt.badge.img+23
  • Aug 20, 2021 8:57 AM UTC
Cheers. Paul
If a WMS responds with text/html it usually means you messed up the GetMap call.
You either are outside the bound of the WMS, there is some NODATA at your location, or you are not logged in, and the text tells you what the problem is.
Look in the log of the workspace to find the response of the WMS (don't look for errors or warnings, just regular messages).
pauledrummond
  • Aug 25, 2021 5:45 AM UTC
Thanks so much.
You are correct, I needed to look at what the GetMap tags were expecting. Specifically GetMap&WIDTH=4096&HEIGHT=4096&STYLES=&FORMAT=image/jpeg
Format must also equal the output Format in the Parameters
I also found that the call would not work without the 'Transparent Background' flag ticked.
Hope this helps someone else.
Regards, Paul
Thanks so much.
Regards, Paul
The transparency thing is due to JPEG not supporting transparency at all, if you need that, see if the WMS offers PNG too.
