WKB geometry
  • Mar 19, 2021 4:31 PM UTC
  • 408 views
boubcher
Forum|alt.badge.img+11
Hello there
I am reading for DB point geometry formated as WKB , how can create a vertex from this wkb filed
ex: (wkb_geometry: 0101000020E6100000F4FFFF87CF5447401BC047148BD43840 )
why the same point read from csv ( lat,lg) file converted to wkb format using geometry extractor transformer has not the same length as the previous wkb stored in database
( 0101000000d81f259db86224417980c06195f54441) wkb extracted (geometry extractor )
thanks
  • Mar 19, 2021 6:00 PM UTC
You can use the GeometryReplacer for this to convert WKB to an FME geometry.
Lots of possible reasons why the WKB isn't identical, the easiest is probably to compare the two resulting FME geometries, e.g. using the Inspector.
