Windows 11 not supported?
  • May 12, 2022 2:13 PM UTC
  • 445 views
I installed the HOME version for my own private research. I am trying to register for a license but cannot activate it.
 ​ -I checked the progress in Task Manager, but it doesn't seem to be working.
-I have used it once in 2019 and it worked then. (Same Machine, OS:Win10)
FME version: FME Desktop 2022.0.0.1 for 64-bit Windows (Build22339)
OS: windows11, 64bit
andreaatsafe
Forum|alt.badge.img+17
Hi @kasutoyo​ ,
Windows 11 is an officially supported operating system for FME 2022. I believe there might be something else happening.
You mentioned you are trying to register for a license but cannot activate it.
Are you able to open the FME Licensing Assistant? Does a dialogue appear or is there nothing?
If you do not see anything appear, can you please review this article and gather the information following steps 1 and 3 under the Windows section. Then please submit the information into a support case.
-Andrea
  • May 14, 2022 2:24 PM UTC
Hi @kasutoyo​ ,
-Andrea
Thank you, @andreaatsafe​ .
I can't open the FME Licensing Assistant., and there is no a dialogue.
I made a trial based on the article you taught me.
Step 1 and step 2-1 (Process Monitor Filter) are ok, ​but from step 2-2, when the Workbench is opened, nothing happens.
Therefore, the process monitor does not operate.
I will continue to validate.
by kasutoyo
  • May 15, 2022 3:23 AM UTC
by kasutoyo
@andreaatsafe​ ​
Additional information.
Normally, the Licensing Assistant should launch when the installation is complete, but nothing happens.
by kasutoyo
It seems like you're facing some activation issues with Windows 11. That can be quite frustrating. Since it worked fine on your machine with Windows 10, it might be worth checking if there's any specific compatibility issue between FME Desktop 2022 and Windows 11.
Before trying to get a new license, it's always a good idea to reach out to their support for assistance. They might have insights or solutions to your problem.
If you're considering Windows 11 keys and tips, you can check out sources like https://digitalchillmart.com/product/windows-11-pro-32-64-bit/.
