Why CoordinateExtractor is generating error. What does this error mean? I am attaching the screenshot of the translationlog for FeatureReader as well as CoordinateExtractor
  • Jul 8, 2022 6:09 AM UTC
  • 5 replies
  • 59 views
rishi1804
Forum|alt.badge.img+4
I am working with FBX files but this is the error I am getting when I am trying to extract the coordinates x, y, z. Because of this issue eventually I fail to create tileset. @kailinatsafe​ @chrisatsafe​ imageimageLog when I running upto the coordinateExtractor after reading and exposing the attributes
muzhnasto
Forum|alt.badge.img+12
  • Jul 8, 2022 9:32 AM UTC
1 FBX do you create yourself ?
2 if yes, in which program ?
3 you can upload a sample file ?
rishi1804
  • Jul 11, 2022 10:15 AM UTC
@muzhnasto​  I have a .nwd file so I have extracted some parts in FBX form using a converter by Navisworks Vision workplace. Flipped the Y,Z coordinates during the conversion(It is needed). I can't upload a sample. I have extracted many parts from the Navisworks model some of them are working with FME and some of them aren't. But I am sure it's an issue with the coordinates.
muzhnasto
  • Jul 18, 2022 10:00 AM UTC
Hi @rishi1804​ I have the same error when reading FBX, but when using the CoordinateExtractor, no error occurs. Apparently the problem is in FBX.
rishi1804
  • Jul 20, 2022 8:30 AM UTC
@muzhnasto​ sorry for late response. In my case fbx file looks absolutely fine in data inspector. I am not having any issue while reading. The translation is successful but when I try to extract the Coordinates it fails. So I am avoiding the extraction but ultimately I need to create Tileset so during Tileset creation it saysimagewhereas I have checked the properties in the data inspector, It is 3D and also I am creating tilesets with other fbx files using the same coordinate system. I used DimensionExtractor as well to confirm. I can't understand what's wrong with tileset creation. @safesoftware safesoftware​ can I get some help on this?
daraghatsafe
Hi @rishi1804​ would you be able to submit a case? If you can provide the workspace and the data that would be really helpful for the specialist that takes the case. Thanks.
