Why are FME Server file geodatabase read speeds slower than Desktop?
  • Oct 8, 2021 1:57 PM UTC
  • 170 views
fneal
Forum|alt.badge.img+4
I have a workspace that reads a database table (no geometry) from a file geodatabase from an on-premise subnet server location. When running the workspace from a Desktop VDI, I get read speeds of ~10K every minute or so. When running the same workspace on Server, I am getting speeds of ~10K records every 6 minutes. I tested to see if the location of the FGDB was the issue by uploading the FGDB as a server resource which resulted in the same slow reading speed. In my experience, Server has always been much faster than Desktop. Has anyone come across this issue?
Desktop
 Server
  • Oct 8, 2021 2:06 PM UTC
My first hunch is that the machine running FME Server might be underdimensioned or struggling. Check for memory and processor usage in particular. Also see if there are other long-running processes or services on the same server that are competing for resources.
fneal
  • Oct 8, 2021 2:21 PM UTC
I checked the performance statistics while running the workspace and nothing jumped out at me. Here is a snapshot of the resources while running the workspace.
ServerResourceMonitor
fneal
  • Oct 8, 2021 6:14 PM UTC
It appears that the slow reading times were due to a WHERE clause with an IN statement isearching through a very large SELECT statement in a different table. I refined the WHERE clause and reading speeds are back to normal.
