Why am I getting these stretched hexagons at the edges of my data?
  • Feb 22, 2021 8:02 PM UTC
  • 78 views
dannymatranga
Forum|alt.badge.img+7
Followed the example provided by @jovitaatsafe​, and the workflow appears to be exactly what I need to do with my data, where I have a number of points in different areas, and want to aggregate by count into hexagons.
The hexagons are also showing up in the ocean near Africa, so I'm guessing this is a map projection issue? But not sure where to resolve it exactly.
2021-02-22_13-55-14
Best answer by jovitaatsafe
Hi @dannymatranga​,
Wow you weren't kidding about the hexagons looking stretched! Can you confirm that you're using a lat/long coordinate system? The H3HexagonalIndexer only accepts lat/long data and the team is working on adding a check to warn or reject data that isn't.
jovitaatsafe
Forum|alt.badge.img+11
  • Feb 22, 2021 9:47 PM UTC
Hi @dannymatranga​,
dannymatranga
  • Feb 25, 2021 5:59 PM UTC
Hi @dannymatranga​,
Hi Jovita, I'm actually using Spherical Mercator (meter), so I'll switch to use WGS84 lat/lon and report back, thanks for the tip!
dannymatranga
  • Feb 25, 2021 8:20 PM UTC
Hi @dannymatranga​,
@jovitaatsafe​ Re-projecting to WGS84 LL worked, thanks again
