Which transformer to use to count the number of joint between connected overhead line and underground cables in ArcMap?
  • Jun 25, 2023 9:17 PM UTC
  • 43 views
jeremiah567
saraatsafe
Forum|alt.badge.img+13
  • Jun 30, 2023 6:42 PM UTC
Hi @Jeremiah Gbolagun​, assuming your input data are both lines, you can try using the LineOnLineOverlayer. Connect both your overhead line and underground cables data to the Line port and the output Points port should tell you how many overlaps there are. I hope this helps!
If this wasn't what you're looking for, feel free to provide some more clarification on your data and what you're trying to achieve. :)
jeremiah567
  • Jul 2, 2023 10:31 PM UTC
Thank you Sara for the heads up.
It is appreciated.
