which format should be used to save data that I want to write to PostGIS?
  • Aug 10, 2022 7:03 AM UTC
  • 48 views
I would like to use the hosted (cloud) solution,
but my database is behind VPC, so there is no direct access from FME to my DB.
how can I save the data in the EWKT or EWKB format, so I could save it by myself to the DB , using a text file? (or a stream in websocket?)
I tried using GML & GeoJson - but they both loose the geometry types and just save as multilineString
hkingsbury
Forum|alt.badge.img+73
  • Aug 10, 2022 8:28 PM UTC
Could you write to a local database, then backup the local instance, and restore it in your hosted instance?
