What tools are replacing the jackson library with fme? (for creating database relation automaticly xml to tables)
  • Nov 17, 2021 8:03 AM UTC
  • 39 views
Forum|alt.badge.img+63
Could you, for the benefit of the people here who don't know what the jackson library is, elaborate a bit about what you want to achieve?
  • Nov 17, 2021 11:26 AM UTC
Jackson library that is converting xml file to model class for relating between tables in database. So, I need create these relations from xml hieararchy in fme automaticaly configuration. Then, I realized this process another way which used inlineQuerier , featureMerger and etc (long way solution). But, I want search smart solution. Do you know any solution for this subject ?
