What are the limits of FME 2022 Comparison
  • Jan 23, 2023 9:49 PM UTC
  • 91 views
carlm
Forum|alt.badge.img+23
I was wondering what are the limit of the 'Compare and merge' feature included in FME 2022.
I have a request to note all the changes made in the workspace and I want to find a way to list those changes. The problem is that I get an error: Unable to compare workspaces. (I have 800 transformer in it with multiple Custom Transformers).
I know this is a bit unrealistic...
Thank you
JennaKAtSafe
Forum|alt.badge.img+9
Hi @carlm​, thank you for brining this to our attention. QA has been done with 1000+ transformers in the 2022 testsuite, so 800 transformers shouldn't be causing this error. I will open a case on your behalf to further investigate this with you.
For future users who run into a similar issue as this, please file a support with "Compare and Merge" in the subject line.
Forum|alt.badge.img+63
I've tried it on a workspace with about 1800 transformers, worked smoothly.
