What advantage does the FME server provide which can not be achieved through the FME desktop on a virtual machine?
  • Mar 23, 2023 6:49 PM UTC
  • 49 views
Since the FME desktop workbench can be run through windows schedular on the VM. Hence what can be the excluding factor for the FME server? Appreciate your views on the same. Thanks
hkingsbury
Forum|alt.badge.img+73
  • Mar 23, 2023 7:52 PM UTC
Automations, calling processes from external applications, centralised view of schedules, self service web apps, CPU Time/Dynamic Engines.
From a simple "I need one job to run everyday at this time" point of view, I can see the benefit of using taskscheduler with Desktop, but you start moving into an enterprise environment, Server becomes a very valuable resource
  • Mar 23, 2023 7:56 PM UTC
Thank you for your response; currently, we are using the FME server as a scheduling tool to run a workbench on a daily scale.
