vertex remover
  • Feb 22, 2023 8:09 AM UTC
  • 7 replies
  • 287 views
bayram
Forum|alt.badge.img+7
Hello
there are vertex at equal distance (0.100) but these are unnecessary, only one vertex in 1m is enough. How can I remove the vertex in between, I looked for vertex remover, but I think I am doing something wrong, can you help me please?
Additional information: There are always 10 vertexes in 1m.
Best answer by nielsgerrits
The Generalizer is the way to go for this kind of work, but I find it hard to control to keep vertices every 1 meter. As an alternative you could use a Chopper to get lines from 1m, rebuild the lines from the first and last coordinate (CoordinateExtractors, VertexCreators) and rebuild the original lines using a LineCombiner. If the vertices are not exactly every 1m, you can create extra vertices using a Densifier before the Chopper.
  • Feb 22, 2023 8:16 AM UTC
Have a look at the Generalizer. Be sure to read up on the different algorithms first to understand the differences:
https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_Transformers/Transformers/generalizer.htm
nielsgerrits
Forum|alt.badge.img+67
  • Feb 22, 2023 9:16 AM UTC
bayram
  • Feb 22, 2023 10:26 AM UTC
hello david
thank you for your answer but i didn't know which commands to use can you help me if i share my file
bayram
  • Feb 22, 2023 11:49 AM UTC
nielsgerrits thank you very much I'm about to reach the conclusion one last problem remained in my file I have more than one line and when I build a line in the same layer, it combines the lines that are separate from each other, how can I prevent this?
bayram
  • Feb 22, 2023 11:50 AM UTC
nielsgerrits
Make sure the original lines have unique id's. This can be done using a UUIDGenerator. Then you can do a group by _uuid in the LineCombiner.
Looking at your workspace screenshot, I think it need to be:
  • UUIDGenerator Chopper (1m)
  • CoordinateExtractor(index 0)
  • CoordinateExtractor(index -1)
  • VertexCreator (Create point, xyz start)
  • VertexCreator (Add point, xyz end)
  • LineCombiner (Group by _uuid)
bayram
  • Feb 22, 2023 2:07 PM UTC
nielsgerrits
I got a very good result, thank you very much for your suggestions
