Versioned geodatabase edit session writes 'successful', but not all are written
  • Jan 26, 2023 2:20 PM UTC
  • 174 views
I am using:
  • FME2021.1 32-bit
  • ArcSDE Geodb writer, truncating the SQL Server table in 10.x geodatabase
  • Versioned Edit Session to feature class that is registered as versioned
  • FME log claims success and that all writes were saved. No errors, warnings or anything indicating an issue in the log at all.
The problem:
Only even 1000 are written. For example, 9454 features result in that FME log displays all written successfully, but only 9000 features exist in the geodatabase. If i use cloner and increase the feature count to even 10 000 all features are saved. Any suggestions?
dustin
Forum|alt.badge.img+36
  • Jan 26, 2023 2:26 PM UTC
That seems really odd. There is a parameter Features per Transaction that defaults to 1000. What happens when you change this to a different value?image
  • Jan 26, 2023 2:28 PM UTC
I have tried setting it to 50, but it still writes 9000.
gistech_
Forum|alt.badge.img+9
  • Mar 18, 2024 2:55 PM UTC
struggling with this issue, has anyone figured the solution to this yet?
ali-safe
Forum|alt.badge.img+24
  • Mar 22, 2024 3:00 PM UTC
Hi, @gistech_.
Sorry for your issue. Could you kindly provide what version of FME Form you are using and, if your comfortable, some screenshots detailing what you are running into? Can take a look further once so.
Thanks!
