Using FME Webhooks with custom parameter inputs and Python
  • Nov 13, 2023 3:59 PM UTC
  • 110 views
Hi there,
We have a workbench that takes as input a KML file, processes it and outputs a zip file.  After testing, this workbench has been uploaded to FME Server, and has data download capabilities.
We want this workbench process to be run via python, with the inputs of the workbench  defined by the user.  We are using Python to upload the user file to the Data folder (FME_SHAREDRESOURCE_DATA)
import requests
folderConnectionURL = "https://xxx/fmerest/v3/resources/connections/FME_SHAREDRESOURCE_DATA/filesys/pvDesign?createDirectories=false&overwrite=true"
uploadedFile = "zzz.kml"
os.rename(outKMZFileClipped, os.path.join(os.path.dirname(outKMZFileClipped), uploadedFile))
outFile = os.path.join(os.path.dirname(outKMZFileClipped), uploadedFile)
headers = {
'Authorization':'fmetoken token=token',
'Content-Disposition': f'attachment;filename={uploadedFile}',
'Accept': 'applicaton/json',
with open(outFile, 'rb') as kmlFile:
files= {'file':(outFile, kmlFile, 'application/octet-stream')}
uploadResponse = requests.post(folderConnectionURL, headers=headers, files=files)
print (uploadResponse.text)
And then once the file has been uploaded, we then want to use that file as the input parameter in a webhook.  The webhook url is as follows:
fmeServerWebhookURL = f"https://xxx/fmedatadownload/Test/CheckForSelfIntersecting3.6.fmw"#?SourceDataset_OGCKML=%24(FME_SHAREDRESOURCE_DATA)%2fpvDesign%2f{os.path.basename(uploadedFile)}&DestDataset_SHAPEFILE=C%3output&opt_showresult=false&opt_servicemode=sync&token=token"
An attempt to upload the user files as the input uses the following code:
payload= {}
headers = {
'Authorization': 'fmetoken token=xyz',
fmeJobResponse = requests.request('POST',fmeServerWebhookURL, headers=headers, data=payload, allow_redirects=False)
print(fmeJobResponse.text)
However, the response is:
java.nio.file.AccessDeniedException: C:\ProgramData\Safe Software\FME Server\resources\system\temp\requestdata\6378309562036833286</div>
If manually run in a browser, the fmeServerWebhookURL states that the FME Data Download Service Completed Successfully, however with no output .zip file available to download.
What may be causing the request to fail, and is it actually possible to generate a webhook url with a parameter (uploaded to the Data folder) ?
Any python examples would be great.
Thanks
itsmatt
Forum|alt.badge.img+48
  • Nov 14, 2023 2:04 PM UTC
So the path:
I think is usually what is created when a POST request has a body and a Reader has been set up to read the content of a POST body (https://docs.safe.com/fme/html/FME-Flow/ReferenceManual/service_datadownload.htm?highlight=%22Using%20data%20from%20HTTP%20POST%20body%20as%20Reader%20dataset%22).
I see in your POST that you have an empty json body {} as the payload. What happens when you leave this empty?
Can you check how the workspace is configured if you try to republish it? Take a look at the DataDownload configuration to see how it's set up -  see if there is anything set to receive messages from the HTTP request.
