using clipper to cut image ,includes black parts around the specific target.Cancel black parts,How?
  • Jul 14, 2021 6:58 AM UTC
  • 69 views
spiderman
Forum|alt.badge.img+7
i have cut specific image with clipper but when i use clipper inside ,i found it includes my target and also black parts around the image that i need to have .how could i cancel black parts ,and keep only my target image ?
  • Jul 14, 2021 7:11 AM UTC
Have you looked at the RasterBandNodataSetter? It will allow you to define the "black parts" as NODATA, rendering them transparent in most clients.
spiderman
  • Jul 14, 2021 7:22 AM UTC
thanks ,it looks what i need and i did nodata value 0 and output in inspector looks great but when i write the output to pdf by pdf writer .it gives me error and unable to write it .
but without using nodata value ,pdf was able to write the image but with black parts .
another hint :i found also some parts of text deleted also after using nodata value . is there another way to remove blackparts only .
could u help me ,thanks again
  • Jul 14, 2021 7:23 AM UTC
Can you share the complete error message please.
spiderman
  • Jul 14, 2021 8:39 AM UTC
hello ,now i am confused . after using RasterBandNodataSetter .it shows me in inspector without nodata ,without black parts but when i write it to pdf by pdf writer.i found,i get now outpu (no error ) but with black parts .what is wrong here?
could you provide me with an example for workspace ,if you do not mind
