User Paramters
  • May 4, 2022 7:11 PM UTC
  • 5 replies
  • 59 views
Forum|alt.badge.img+3
I have a series of user parameters that will display when I use preview but when I run the workspace the last one won't display. I can't see any options where a parameter wouldn't be visible when running the workspace. Is there a limit to the number of user parameters that can be set?
dustin
Forum|alt.badge.img+36
  • May 4, 2022 7:20 PM UTC
Make sure the Published check box is checked.
  • May 4, 2022 7:29 PM UTC
It's definitely checked.
dustin
  • May 4, 2022 7:32 PM UTC
@chris28​ By chance, are you only running a certain section of the workbench with Enable Feature Caching checked? When doing that, it will only display the parameters needed to run to that specific point.
  • May 4, 2022 7:34 PM UTC
No, I'm running the entire workspace.
j.botterill
Forum|alt.badge.img+69
  • May 5, 2022 12:08 AM UTC
Maybe also check that the Run with Prompt is on.. when you run the entire workspace it should ask for the 'published' user parameterRunwithPrompt
