Use AD Group in FME Server
  • Mar 24, 2023 10:22 PM UTC
  • 92 views
Hello,
We are looking to use an Active Directory group as a Role in FME Server. I'm able to import an AD group and use the Load Template button to grant the AD Group the same set of permissions as the "fmeadmin" role. The Load Template dialog does not have superuser role as an option. Is it possible to set up an AD group as superuser role?
Thanks,
Vu Dang
itsmatt
Forum|alt.badge.img+48
  • Mar 27, 2023 7:41 AM UTC
I think that's been done on purpose. How many users are you wanting to make superuser? I'd suggest just using the fmeadmin template and then manually add the fmesuperuser role as needed directly to the user.
