Upload GDB to AGOL?
  • Feb 10, 2023 4:17 PM UTC
  • 212 views
vxn43
Forum|alt.badge.img+20
Is it possible to upload a zipped File Geodatabase into a specific folder in an AGOL user account using FME? if yes, what would be the best transformer(s) to use?
Best answer by debbiatsafe
Hi @timh​
The ArcGISOnlineConnector transformer should allow you to upload a zipped file geodatabase to ArcGIS Online. The transformer allows you to specify the user content folder you want the file to be uploaded to. There is a tutorial on using the ArcGISOnlineConnector that includes an example on uploading a file to AGOL in case it helps.
debbiatsafe
Forum|alt.badge.img+24
  • Feb 10, 2023 7:05 PM UTC
Hi @timh​
