Update smallworld with FME
  • Nov 24, 2023 10:45 AM UTC
  • 131 views
Hi everyone,
I'm new to Smallworld and FME working together. The only thing I'd like to achieve to update one attribute, not the geometry. I set fme_db_operation = UPDATE and I didn't give any geometry information. After running workspace i could see a few records being updated but translation failed with this message:
Number of Features: 1
Connecting to Smallworld on localhost:30000 using service FMENOFACTORY
Table: 'gis.point_of_interest'
NumberOfAttributes: 16
Processing a point
Error running translation.
Do you have any idea why this happens?
Many thanks
hkingsbury
Forum|alt.badge.img+73
  • Nov 26, 2023 7:33 PM UTC
Does the smallworld writer have this field?
imageIf you don't want to update the geometry, you will need to set this to no. Even though you removed the geometry, your still telling the writer to update a point feature with a null geometry. This could be the cause of the issue
  • Nov 27, 2023 8:07 AM UTC
Thank you for your answer.
My problem is that with Smallworld writer I don't have such options to set these things like I had with Oracle spatial. I only can give server name, port and alternative to use.
hkingsbury
  • Nov 27, 2023 7:04 PM UTC
Unfortunately I don't have access to any smallworld environments to explore other options. It's probably best to reach out to support regarding this
