Unable to produce extruded citygml from shapefile
  • Aug 3, 2022 4:40 PM UTC
  • 83 views
I'm trying to take a simple shapefile and transform it to citygml. I've found a couple solutions that suggest all I need is what it defined in my attached workspace but the output doesn't seem to honor my extruded geometry. Any ideas what I'm doing wrong?
And here is a picture of the workspace if that helps.
fme
  • Aug 5, 2022 2:15 AM UTC
I've gotten further but the transformed citygml is not projected correctly. Using Data Inspector my shapefile is CS_NAME: _LL-WGS84_ and I've left the Coordinate System as <not set>
When I inspect the generated citygml inside of FME Workbench it looks correct
citygml_viewWhen I open the citygml file into QGIS, it looks like this where all the geometry is at the south pole.
qgis
Any ideas what is happening here?
itsmatt
Forum|alt.badge.img+48
  • Aug 9, 2022 11:46 AM UTC
qgis
Did you make any progress? it could be that the axis are flipped in the output file. There is a setting on the writer to specify the Srs axis or something. check that out.
Otherwise I'd also suggest using a projection like SPHERICAL_MECATOR or something to keep it in meters. Might make it easier
  • Aug 10, 2022 3:57 PM UTC
I ended up using a CoordinateSwapper before the writer to correct the issue. Seems weird that I had to do that but I'll check out the Srs axis options. Thanks!
  • Aug 10, 2022 4:37 PM UTC
Here changes to the writer worked for meCapture3
