Unable to copy data
  • Mar 23, 2023 10:53 AM UTC
  • 108 views
jitsu87
Hi Team,
I am trying to copy data from gdb feature class to another feature class but i am getting below error. please help me understand the error. I have changed the permission settings & schema also matched.
Error :
Geodatabase Error (-2147220987): The user does not have permission to execute the operation.
FileGDB Writer: A feature could not be written
Feature Type: `WaterDataset/WaterDistributionDevice'
Attribute(64 bit real)       : `diameter' has value `600'
Attribute(64 bit real)       : `elevation' has value `309.255'
Attribute(string: UTF-8)      : `facilityid' has value `Pratap Nagar'
Attribute(string: UTF-8)      : `filegdb_type' has value `geodb_point'
Attribute(string: UTF-8)      : `fme_feature_type' has value `Test3'
Attribute(string: UTF-8)      : `fme_geometry' has value `fme_point'
Attribute(entangled: string: UTF-8): `fme_type' has value `fme_point'
     entangled to filegdb_type, shapefile_type
Attribute(string: UTF-8)      : `label' has value `Pratap Nagar'
Attribute(string: UTF-8)      : `multi_writer_id' has value `1'
Attribute(string: UTF-8)      : `notes' has value `FCV'
Attribute(64 bit integer)     : `objectid' has value `1'
Attribute(string: UTF-8)      : `shapefile_type' has value `shapefile_point'
Coordinate System: `_UTM84-44N_0'
Geometry Type: IFMEPoint
Name(UTF-8): `shapefile'
Coordinate Dimension: 3
(297683.99370000046,2336099.3280999996,0)
FILEGDB writer: An error has occurred. Check the logfile above for details.
itsmatt
Forum|alt.badge.img+48
  • Mar 27, 2023 6:42 AM UTC
Do you have access to an ESRI File Geodatabase writer or only the FILEGDB writer. I just did a quick search hand found this on ESRI: https://community.esri.com/t5/file-geodatabase-api-questions/the-user-does-not-have-permission-to-execute-the/td-p/325039
Is it possible that the datatype in the Feature Class is one listed in the link?
jitsu87
  • Mar 27, 2023 7:26 AM UTC
@virtualcitymatt​ Hi,
I am afraid that I am not able to understand the difference between only FILEGDB writers &  ESRI File Geodatabase writers. Could you please elaborate?
Yes, the datatype is same as mentioned in the link.
itsmatt
  • Mar 27, 2023 8:39 AM UTC
The Esri Geodatabse (File Geodb Open API) or FILEGDB for short uses an open API and is available with all versions of FME.
The Esri Geodatabse (File Geodb) or GEODATABASE_FILE for short uses the actual ESRI api and therefore requires an ESRI Edition of FME (see here: https://www.safe.com/pricing/fme-desktop/).
You will also need to have an appropriate ESRI license available on the machine (see here: https://community.safe.com/s/article/notes-on-fme-and-esri-versions-and-compatibility)
Here is a screen shot of the format list so you can see what I'm talking about:
jitsu87
  • Mar 27, 2023 12:23 PM UTC
@virtualcitymatt​ thanks for the clarification
I tried using both the writer formats but still getting the same error ...even schema has no difference.
Please help me ​
