Unable to connect Delete Writer to Reader
  • Feb 16, 2021 6:26 PM UTC
  • 90 views
Hi
Added Reader to extract from Access db source and then insert into destination SQL db (right hand side) and it worked fine:
FMEWanted to add a writer to delete all db records (on the far left) before the reader. However, unable to connect that writer to the reader. Any advice on how can I execute that Delete Writer before the Reader? Thanks.
Best answer by nielsgerrits
You can use FeatureReaders / FeatureWriters for this kind of workflow. If you have no features to initiate the proces, you can put a Creator transformer in front of the FeatureReader.
nielsgerrits
Forum|alt.badge.img+67
  • Feb 16, 2021 6:33 PM UTC
  • Feb 16, 2021 8:07 PM UTC
Thanks
Created new Feature Writer as below to delete SQL records:server1Able to link that ti AttributeManager and FeatureReader:
server2Ran the FeatureWriter but nothing got deleted in the SQL db. Anything that I missed?
