Unable to check out an Esri license. Please ensure ArcGIS is correctly licensed and that there are available licenses
  • Feb 8, 2017 6:53 AM UTC
  • 132 views
Dear all ,
We are unable to connect FME desktop 32 Bit on windows server 2012 to SQL SDE or geodatabase , we are using arcgis desktop 10.5 but it works fine on PC , Any Idea have to investigate the issue .
Thanks ,
ngoorman
Forum|alt.badge.img+3
  • Feb 8, 2017 10:28 AM UTC
to use ArcGIS 10.5 licenses, you will need to use FME Desktop version 2016.1.3 or higher. That might explain your issue if you are still using an older version of FME. You can read more about compatibility with ArcGIS on
https://knowledge.safe.com/articles/1517/notes-on-fme-and-esri-versions-and-compatibility.html
But it works fine on workstation with the same version of FME and Desktop but it doesn't work on the server
