Trouble Uploading File to SFTP via FME Server
  • Aug 9, 2021 2:25 PM UTC
  • 262 views
Hello,
I have an FTP Caller which works fine to upload a file to an SFTP connection using FME Desktop (on version 2019.2).
imgHowever, on FME server (version 2019.2) it fails with this error:
img2With guidance from this post: https://community.safe.com/s/question/0D54Q00008B1IFh/problem-with-ftpcaller-and-sftp I also tried publishing the workspace in a newer version (2020.1) and running in on FME Server (2019.1 and 2021.1) but without success.
Any help?
hkingsbury
Forum|alt.badge.img+73
  • Aug 9, 2021 8:20 PM UTC
Does your server have the required (s)ftp ports open? The defaults are 20,21,22.
smol
  • Aug 10, 2021 8:56 AM UTC
Note that the OP tries to upload through SFTP to an external SFTP server from a Workbench running on an FME Server. This means the connection is outbound which should not require any ports to open (?).
hkingsbury
  • Aug 11, 2021 12:46 AM UTC
Its still worth checking. I've worked in numerous environments where all communication (in and out) is closed by default and any communication channel needed to be manually opened
smol
  • Aug 16, 2021 3:17 PM UTC
The FME Administrator of the OP here. The outgoing port(s) seems to be fully open.
PORT   STATE SERVICE
22/tcp open  ssh
21/tcp open  ftp
20/tcp open  ftp-data
