trouble Restricting Licenses
  • Aug 18, 2020 7:10 AM UTC
  • 65 views
I am trying to restrict licence on a floating licence server to a certain machine and i did as instructed in here:
http://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_Desktop_Admin_Guide/FMEInstallation/Restricting_Licenses_to_Users_or_Groups.htm
and create a safe.opt in the same folder as safe.exe in the FlexServer folder with the safe.opt content as :
RESERVE 1 professional HOST_GROUP groupA
HOST_GROUP groupA GIS-TEST2
i thought the problem was that i need to restart the server but still not working even though in the log file it clearly says :
(safe) Using options file: "C:\\Program Files\\FlexServer\\safe.opt"
i thought the problem was with the name of the machine (which i got from running "lmutil lmstat -a -c safe.lic" while it was connected) so i tried again using the IP instead but still not working
Best answer by david_r
Are you sure that you're running the Professional edition of FME? You have to reference the FME edition on the first line, e.g. for the ESRI edition:
RESERVE 1 esri HOST_GROUP groupA
  • Aug 18, 2020 7:39 AM UTC
  • Aug 20, 2020 7:16 AM UTC
Yeah that was it actually
Thanks man
