Transpose the Name Coumn
  • Jun 24, 2022 11:01 PM UTC
  • 7 replies
  • 60 views
asadamjad
Participant
Forum|alt.badge.img+12
i am trying to Transpose Name fields as a Column and Value are vales
i tried attribute creater and data coming like this its sholud b in one row
danilo_fme
Forum|alt.badge.img+58
  • Jun 24, 2022 11:49 PM UTC
Hi @asadamjad​
Could you share the file?
Thanks in Advance,
Danilo
asadamjad
Participant
  • Participant
  • Jun 25, 2022 12:35 AM UTC
here its is
also i am try to do is tester for current year so it will chnage year automaticcly how can i do tht
asadamjad
Participant
  • Participant
  • Jun 25, 2022 10:08 AM UTC
any one
danilo_fme
  • Jun 25, 2022 11:45 AM UTC
any one
Thanks @asadamjad​
I used transformers (attached):
Attributes
Thanks in Advance,
Danilo
asadamjad
Participant
  • Participant
  • Jun 25, 2022 12:56 PM UTC
and what about the Current year ?
asadamjad
Participant
  • Participant
  • Jun 25, 2022 1:07 PM UTC
i am getting error will you have any idea why
image"Dropping heterogeneous aggregate feature for the ARCGISPORTALFEATURES Writer, due to feature type allowed geometries restriction"
rahulsharma
Hi @asadamjad​
The error that you are receiving is due to fact that you are attempting to write "fme_aggregate" to a fme_polyline feature (ArcGIS Portal).
You could use geometry filter transformer to fix that or use my workspace below, which should have the expected result (as long as you are writing to a new FeatureService).
In case, you are writing to existing FeatureService, please ensure that incoming attribute names and data type match those on the server.
