Transformers are deselected when panning.
  • Nov 30, 2020 11:08 AM UTC
  • 6 replies
  • 67 views
nielsgerrits
Forum|alt.badge.img+67
When I re-organize the transformers in a 2019 workspace, the selected transformers are being deselected when panning.
  • Select by fence with the left mouse button.
  • Zoom using CTRL and scroll wheel.
  • Pan clicking the middle mouse / scroll button.
I'm quite sure it worked this way in previous versions.
Is this a setting which can be changed? If not, am I the only one having this issue?
Forum|alt.badge.img+54
  • Nov 30, 2020 11:38 AM UTC
I've never ever used pan before, but it's still working like that in 2019 for me.
nielsgerrits
Thanks for checking, will try and fix in the mouse config.
  • Nov 30, 2020 12:01 PM UTC
If you select the pan icon and try and pan that way do you get the same issue? If not suggests it's something mouse-y
nielsgerrits
Hmm, it does deselect when using the pan icon too...
Do you have "Canvas selection must fully contain objects" checked? If I check that, it works without deselecting. Will start puzzle which I prefer more, selected panning or partial selections.
  • Nov 30, 2020 12:10 PM UTC
Yes, that's the difference. I have it selected. If i un check that transformers are deselected when panning
nielsgerrits
Thanks again for checking. Will learn to work with the option checked and submit a case. Might be an easy fix.
