TopologyBuilder not ordering nodes correctly
  • Dec 29, 2022 7:14 PM UTC
  • 6 replies
  • 134 views
tmatiques
I have a network that is just input lines from shapefiles.
All line ends are snapped together correctly. The network has an origin point that is a point feature shapefile.
I want to be able to run the TopologyBuilder and assign that origin point as node 1. From there, each subsequent intersection of the lines where a new node is created should be incremental from the origin Node 1.
In my attached picture you can see the top part of the image is what I want.TopologyBuilder IssuesThe bottom section of the image is what comes out.
In the TopologyBuilder I am using end nodes only, so there is no overlapping intersections creating false nodes.
I have tried to plug the network into the NetworkFlowOrientor and it does not do anything if I then rebuild the topology after it.
Does anyone have any ideas as to what could be causing this, or how to set an origin node to build a topology on?
*As a side note, I can identify the origin node ID and from there each line segment has the from and to, however I do not know how to order the results using the from and to attributes given that are out of order. Any suggestions on this as well?
For instance, if the origin node is 5, and a line segment is from 5 to 1, and then the next line segment should be from 1 to 2.
Cheers,
DanAtSafe
Forum|alt.badge.img+23
  • Dec 29, 2022 8:46 PM UTC
Hi @tmatiques​ Try the NetworkCostCalculator. This will return measures starting with 0. Break the lines into points, remove duplicates, sort by the measure and recount:
imagewhich produces
tmatiques
  • Dec 29, 2022 9:24 PM UTC
Hey Dan,
Thanks for the quick response. I ran through your steps with my network and get the same result (albeit a different set of lines.
However, this is just marking the nodes based on the shortest distance to the origin node.
What I need for instance is the following:
node_order_issueOr if that is not possible, a way to order the edges based on the from and to. Taking your output the records would look like this:
Edge1 - From 1 - To 2
Edge2 - From 2 - To 5
Edge3 - From 5 - To 9
Edge4 - From 5 - To 10
Edge5 - From 1 - To 4
Edge6 - From 1 - To 3
Edge7 - From 3 - To 7
Edge8 - From 7 - To 8
Edge9 - From 3 - To 6
Edge10 - From 6 to 11
If I can sort like this, I can then apply a counter and label the nodes correctly.
Here is a picture of my actual network just for reference:
my_network
DanAtSafe
  • Dec 29, 2022 10:35 PM UTC
I don't know what the logic would be to assign edges as you've described. How should the edges be ordered with your "actual network"?
tmatiques
  • Dec 29, 2022 10:48 PM UTC
I will try my best to explain the logic. I have attached another picture, this is basically a manually created straight line diagram to represent fibre cable installation routes and the associated nodes that customers connect to. You will notice that from the origin node (redish block) each cable leg has the nodes labelled sequentially (U001>U002, etc). Nodes labelled with an "S001" are not part of the sequential labels.
network_sld
How the legs get labelled a or b or c doesn't really matter, what matters is for each cable leg, I am able to number the nodes sequentially so I can create the diagram pictured above.
We currently make these manually.
danilo_fme
Forum|alt.badge.img+58
  • Dec 31, 2022 12:25 PM UTC
imagewhich produces
Great @danatsafe​
elmido13
Forum|alt.badge.img+4
  • Oct 11, 2023 1:09 PM UTC
@tmatiques​ did you sorted this out?
