This feels a bit silly, but how do I stop AttributeManager Parameter Condition from autofilling my expressions?
  • Sep 17, 2021 6:14 PM UTC
  • 5 replies
  • 56 views
PicI am currently just working on some of the modules as I am trying to learn FME, but when I manually set the final line for some of my expressions as just ")" it automatically sets an "=" for my Operator and then changes my logic to ") AND". For some of my conditions I've been able to simply put the final parenthesis and be okay, however, the attached image is where I am running into issues. Line 7 just keeps switching itself to ") AND".
How can I use the ")" logic without it auto resetting to ") AND"?
nielsgerrits
Forum|alt.badge.img+67
I can only add I have the same experience, I think since 2021.
  • Sep 17, 2021 7:16 PM UTC
Thanks for also inputting that you're having an issue. I'd rather it default to not anything than for it to automatically set anything.
JennaKAtSafe
Forum|alt.badge.img+9
Hi @hodzic12​, I was able to repro this issue and it does seem to be a bug. I have passed this along to our development team to take a look! For reference, the ticket number for this issue is FMEDESKTOP-11974
JennaKAtSafe
I can confirm this is no longer an issue on FME 2022.0 and above! Thank you for spotting this issue.
  • Jan 29, 2022 2:54 AM UTC
@hodzic12​ , ​I think the issue has been resolved in the current version of FME.
If you feel inconvenience to set the Logic column, try editing the composite expression in the "Composite Expression" section instead. Click [Edit] button to start editing.
conditional-value-setting
