The created components in LAS-data didn't show up in ArcGIS Pro
  • Mar 2, 2022 2:00 PM UTC
  • 105 views
quangu
Hi! I have created components (resistivity and resistivity_class) in a LAS-data. When i uploaded it in FME inspector, the created components showed up, but not in ArcGIS Pro. Any ideas how I can make it to show up in ArcGIS Pro?
FMEPro
hkingsbury
Forum|alt.badge.img+73
  • Mar 2, 2022 6:59 PM UTC
You're doing everything right on the FME side of things, but I feel like there may be limited support in other software packages for custom components on LAS files....
Keen to hear if anyone else has a solution.... @mark2atsafe​  or @dmitribagh​ ?
dmitribagh
Forum|alt.badge.img+20
  • Mar 2, 2022 8:03 PM UTC
Hi @quangu​ ,
I think, as @hkingsbury​ said above, you are doing everything correctly. I just made a LAS file with a custom component, and checked it in ArcGIS - I cannot see it there. Still, the component is there - I saved the LAS under the new name in ArcGIS, and check in FME - the component was preserved, so this is probably a question to Esri whether they can display user components stored in the LAS files.
Dmitri
quangu
  • Mar 3, 2022 6:53 AM UTC
Thank you for your responses!
