the AreaOnAreaOverlayer efficiency is very slow compared with arcgis,is there any other replace?
  • Jan 6, 2022 2:14 AM UTC
  • 5 replies
  • 116 views
  • Jan 6, 2022 4:59 AM UTC
Hi @bouyeijiang​ , these transformers process area geometries based on their spatially relationship.
  • AreaOnAreaOverlayer
  • Clipper
  • SpatialFilter
  • SpatialRelator
Which one should be used depends on what kind result you want.
I mean, slow execution
  • Jan 6, 2022 9:23 AM UTC
I understand what you mean, but I don't think ArcGIS has a function exactly same as AreaOnAreaOverlayer. I therefore thought there might be a workaround using other transformer to get your desired result more efficiently.
If it's a case where only the AreaOnAreaOverlayer can generate your desired result, I think there is no way to improve performance except upgrading machine spec.
mark2atsafe
Forum|alt.badge.img+59
If you look in the help docs there is a section about which different transformers are available and how their performance varies:
The Clipper is probably faster, but as Takashi says, it may not be the exact same functionality.
I'm trying the clipper transformer,it's seems a little faster but the intersection with arcgis is much wrose
