terminate translation if one of the input tables is empty
  • Apr 14, 2022 11:47 AM UTC
  • 160 views
nicolae.soare
Forum|alt.badge.img+3
hello,
I have a workspace with 2 tables. these tables are automatically populated.
in the translation is a FeatureJoiner (left join) which joins the data from these 2 tables and "moves" it further..
Is it any possibility to stop the translation after running it if one of the input tables is empty(no records)?
Thank you
Nicu
Best answer by dustin
Have a look at the NoFeaturesTester in the FMEHub. NoFeaturesTester | FME Hub (safe.com)
Make a connection from the table to the NoFeatureTester. From the NOINPUT port, connect a Terminator. This will terminate the translation if the table is empty.
dustin
Forum|alt.badge.img+36
  • Apr 14, 2022 12:31 PM UTC
nicolae.soare
  • Apr 18, 2022 6:49 AM UTC
Thank you! This works perfect.
