Tag touching pairs of endpoints?
  • Aug 25, 2020 8:11 AM UTC
  • 5 replies
  • 108 views
aron
Forum|alt.badge.img+16
I would like to ad identifiers to pairs of "touching" endpoints. So if two endpoints touch (or are within a given buffer) they are to be tagged with an identifier that is unique to this pair. Lets say that the first two touching endpoints both are tagged with 1 (or A), the next pair with 2 (or B) and so on. How can I achieve this?
Best answer by david_r
Hi @david_r​,
I have looked at TopologyBuilder but I found no way to ad the same identifier to a pair of nodes. I know one can collect info about the neighbouring objects, but that does not really help me, I would like both end nodes to have the same unique identifier.
But to be honest I find the TopologyBuilder quite hard to understand, so there might be some aspect I have missed.
In the TopologyBuilder advanced parameters, set Generate from = End nodes only.
On the output port Edge, look at the attributes _from_node and _to_node, they will contain the common ID where lines meet.
  • Aug 25, 2020 8:27 AM UTC
Have you looked at the TopologyBuilder? Would that fit?
aron
  • Aug 25, 2020 8:37 AM UTC
Hi @david_r​,
  • Aug 25, 2020 8:56 AM UTC
Hi @david_r​,
aron
  • Aug 25, 2020 9:22 AM UTC
Hi @david_r​,
Thanks @david_r​ ! Will try this. The TopologyBuilder sure is one advanced (and mindboggling) transformer :)
  • Aug 25, 2020 12:01 PM UTC
Hi @david_r​,
Indeed, it is very powerful. For more information I can recommend the documentation, as well as the tutorial series here, in particular the first example: https://community.safe.com/s/article/working-with-networks-topology-and-networktransfor
