Superfluous Attribute Transfer
  • May 5, 2022 9:12 AM UTC
  • 28 views
mukhtarg
Forum|alt.badge.img+4
Hello Experts,
I have 3 files
A: Point File
B : Line file (Street)
C : Line file (Street2)
I have extracted Street names from the A point file and transferred them to the closest street B. But unfortunately, the street names have been populated to streets within provided distance. This has caused superfluous names to the streets. I need to populate the street name to the streets where the names are missing, but it also should not be available in the polyline file C. Basically i want to identify the superfluous names.
Any help would be highly appreciated
caracadrian
Forum|alt.badge.img+23
  • May 5, 2022 12:07 PM UTC
In this case, you could Hull the points GroupedBy street name.
Create ID's for line geometries, GeometryExtractor to put geometry in attribute, LineOnAreaOverlayer to intersect lines with hulls, then get the length of each resulting line, sent to StatisticsCalculator to get max.length, Tester length=max.length and, finally, GeometryReplacer to get the initial geometry of the line back.
