Suggestion required for use of FME in Nuclear Power Plant @ Surveying and Construction data
  • Mar 16, 2022 9:51 AM UTC
  • 47 views
magi
Hi Please am looking for your INPUTS on different idea what kind of services we could develop. What are mote transformer for this industry . Data is mostly from indoor Surveying Data ( point cloud)
OPEN to any suggestion, ideas or help . Highly obliged with your response. thank you
danminneyatsaf
Forum|alt.badge.img+13
Hi @magi​
If you haven't yet, I recommend taking a quick look through this article on getting started with Point Clouds in FME.
However, for a more advanced topic, we have an article on Profiling and Slicing Point Clouds. This example shows how information can be extracted using both a shapefile and point cloud to begin surveying for a mock road upgrade. This process is much more realistic for surveyors and engineers that may require ground data prior to any sort of construction.
Hope this helps!
magi
  • Mar 18, 2022 1:32 PM UTC
thank you for response :)
