Stroking CurvePolygon/CompoundCurves
  • Jan 19, 2023 5:29 AM UTC
  • 97 views
I note that ArcStroker will stroke CircularStrings but my testing indicates it won't stroke CurvePolygons and CompoundCurves. What transformer will allow me to so stroke those geometries?
Simon
daveatsafe
Forum|alt.badge.img+24
  • Jan 26, 2023 11:03 PM UTC
Hi @simongreener​,
Please provide a sample of your CurvePolygons and CompoundCurves, and I will see if FME can stroke them for you.
Hi @simongreener​,
Dave,
I have tried to replicate the problem I was seeing.
I can't find the original geometry data that was causing the problem (there are hundreds of thousands of WKT of mixed quality).
ArcStroker behaves against the following SQLCreator SQL:
select id,geom
  from (select 1 as id,geometry::STGeomFromText('CIRCULARSTRING(-2 0,1 1,0 0)',0) as geom
        union all
        select 2 as id,geometry::STGeomFromText('COMPOUNDCURVE((-2 -2,-2 0),CIRCULARSTRING(-2 0,1 1,0 0))',0) as geom
        union all
        select 3 as id,geometry::STGeomFromText('CURVEPOLYGON(COMPOUNDCURVE((1 1,0 2,-2 0),CIRCULARSTRING(-2 0,-1 -1,0 0),(0 0,1 1)))',0) as geom
        union all
        select 4 as id,geometry::STGeomFromText('GEOMETRYCOLLECTION (CURVEPOLYGON(COMPOUNDCURVE((1 1,0 2,-2 0),CIRCULARSTRING(-2 0,-1 -1,0 0),(0 0,1 1))))',0) as geom
) as g
I hope I didn't waste any of your time.
Simon
