StringReplacer bug?
  • Oct 8, 2021 10:01 AM UTC
  • 94 views
jatoxa
Forum|alt.badge.img+12
Hi all,
When I try to replace "back slash" in a directory path to "forward slash" it works in all but the last occurence. Tried with Regex as well.
Since I'm passing the path to a PythonCaller where I have to use double forward slash I get output similar to this: "C://Folder//AnotherFolder//3rdFolder/lastfolder".
I tried using AttributeSplitter and ListConcatenator and use // as delimiter.
The output is the same and the last occurence doesn't have double forward slash: "C://Folder//AnotherFolder//3rdFolder/lastfolder".
Is there some fundamental logic to this I'm not familiar with or is it a bug?
Also I run the 2021.2 Beta, don't know if it could have anything to do with that.
Thanks!
jatoxa
  • Oct 8, 2021 10:13 AM UTC
I just noticed that since I have my path as a published parameter it changes the last occurence of back slash to forward slash automatically when I run the workspace. This explains the above mentioned behaviour so it's not a bug.
