Strange freeing memory limits in job log
  • Oct 26, 2022 3:21 PM UTC
  • 79 views
Hello,
We are experiencing strange memory limits messages in job log:
2022-10-26 16:31:36 | System Status: 20.00 GB of physical memory available
2022-10-26 16:31:36 | System Status: 30.00 GB of virtual memory available
2022-10-26 16:31:37 | FME Configuration: Start freeing memory when the process exceeds 60.00 GB
2022-10-26 16:31:37 | FME Configuration: Stop freeing memory when the process is below 45.00 GB
How are these limits calculated, because start and stop freeing memory limits are greater in size than the available physical/virtual memory?
@miro.vrbanic​ The messages are explained here
Thank you @Mark Stoakes​.
We checked that article before, it explains general settings and messages about memory management.
We have a situation that during job log "just stops" and job fails because engine crashes (restarts).
In fmeprocessmonitorengine.log there is no "memory related" messages, just the general:
Fri-04-Nov-2022 08:40:42.657 PM  WARN   Engine1  393562 : Process "Engine1" ended unexpectedly. Being restarted on attempt 1...
On Windows server running the FME Core/Engine we monitored memory usage using PerfMon and in the moment of engine crash, there was 1.8 GB of physical memory available.
That's why we suspect that the FME calculated the freeing memory limits in a bad way, and in reality never started the optimizing process.
We are running:
FME Server 2021.2.4
Build 21814 - win64
We are running:
FME Server 2021.2.4
Build 21814 - win64
@miro.vrbanic​ This is likely an FME engine crash - probably not related to memory. What does the job log say? If there is no error in the job log then it's very likely an FME crash. Try testing the workspace on FME Desktop. If that also crashed then with an error in the workbench log "Error running translation" then you'll need to start disabling parts of your workspace until you find the offending part
