Splitting addresses question
  • Jan 31, 2023 10:56 PM UTC
  • 152 views
vxn43
Forum|alt.badge.img+20
I have an address field with an address value of 1244 Deep Creek Road
I want to use the AttributeSplitter to separate this value in a List so it comes out like this
List{0} = 1244
List{1} = Deep Creek
List{2} = Road
My question:
What delimiter do I need to use that would split the 1244 into a separate list, but keep the "Deep Creek" together in List{1}? (Note that there are other streets with two names, I use "Deep Creek" as an example)
Best answer by daveatsafe
Hi @timh​,
The AttributeSplitter is not sophisticated enough to do that type of separation, but the StringSearcher can do it it using Regular Expressions. Please try the StringSearcher with the following Settings:
Screen Shot 2023-01-31 at 4.03.02 PMThe Regular expression to use is:
([0-9]+) ((?:\w+ )+)(\w+$)
This will result in a list of three parts, with the first part being the street number, the last part being the last word, and the middle part being all the words between the other two.
The Regular Expressions are very powerful for this sort of splitting. There is great RegEx experimentation site that I use a lot at https://regexr.com/.
daveatsafe
Forum|alt.badge.img+24
  • Feb 1, 2023 12:10 AM UTC
Hi @timh​,
danilo_fme
Forum|alt.badge.img+58
  • Feb 1, 2023 12:14 AM UTC
Hi @timh​
I simulated here using Regex to get firt integer elements:
Workspace_Integer_1
Thanks in Advance,
Danilo
