Something strange with date
  • Sep 17, 2020 2:39 PM UTC
  • 29 views
melanied
Hello,
I submit this very simple workspace that writes three text files containing the current date obtained in different ways from a private parameter (Today).
I get 3 different files when I thought I could get the same 3 files. Moreover, there is no problem to create directories containing the date.
Unless I'm mistaken, it looks like a bug. Especially since when I designed the workspace, test1.txt contained the expected result... If the .fmw is copied or moved, the problem occurs.
I ran this workspace on version 2020.1 (FME(R) 2020.1.1 (20200817 - Build 20614 - WIN64).
caracadrian
Forum|alt.badge.img+23
  • Sep 18, 2020 5:28 AM UTC
It looks like there are different implementations of Parameter handling.Today definition
The way $Today is defined you shouldn't get anything else then @Left(@DateTimeNow(),8) without using @Evaluate. Lets wait for someone from Safe to comment on this.
