...so simple? Just want to select a specific raster (geotiff) value...
  • Nov 16, 2020 12:46 PM UTC
  • 90 views
harmen_kampinga
I have a GeoTIFF file (real32) with one band(0)
Like to extract just the value 0.4 from it.
But whatever I try, nothing works out.
It's so simple, but I can't see it....
With the RasterExpressionEvaluator I use this expression:
@if(A[0]==0.4,0.4,0)
The only result I get is : 0
Probably because the band only contains RGB values whereas the z-value 0.4 is interpreted? But what then, is the best way to extract this?
harmen_kampinga
Well... solved it in a way...
Just by using this:
First rounding the values of the grid to 4 decimals and then:
A[0]<0.3999 || A[0]>4.001
