snap
  • Jun 16, 2022 6:46 AM UTC
  • 32 views
bayram
Forum|alt.badge.img+7
Hello ,
I have dots and texts in my workspace. My writings must be attached to the point data. In the picture, the correct text in the 1st example is attached to the point data, but in the 2nd example, the text is not attached to the point data, how can I detect the non-adhesive text or point data?
Best answer by redgeographics
You can use an AnchoredSnapper (using your points as the anchors) to connect the texts to the points. Do note that it will simply look for the closest match, so depending on the layout of your points and texts that may not be the correct one.
Forum|alt.badge.img+63
