Sitter min licens fast i hårdvaran?
  • Nov 18, 2021 12:56 PM UTC
  • 44 views
Jag vill flytta min licens från en dator till en annan. Måste jag ta med hela programvaran eller kan flytta licensen mellan datorerna ändå?
Best answer by david_r
It depends on if you have a floating or fixed license. You can find a complete description here: https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_Desktop_Admin_Guide/FMEInstallation/Licensing.htm
The easiest is probably to simply contact your FME reseller/partner and they'll be glad to help you out.
Do my licence stick to the software?
Or can I move my licence between computers?
  • Nov 18, 2021 2:31 PM UTC
