Simplifying polygons with gaps
  • Jun 9, 2023 12:56 PM UTC
  • 107 views
albinepro
Forum|alt.badge.img+7
I have some floor plan DWG drawing with gaps (walls) between the rooms. The desired result is to make it simplified floor plan, i.e. keep just one line between the rooms.
obrazek.pngThere are hatches that forms the basic shape of polygons to begin with. So far I could get rid of gaps by buffering twice (positive and negative), dividing overlaps and dissolving small artefact sliver polygons to bigger ones. Later snapping the segments. The result is more or less satisfying, I just wonder if there's more elegant solution.
polygFor example the snapper (segment) doesn't maintain the orthogonality and makes "crooked" lines...
Thanks for any suggestions.
Forum|alt.badge.img+63
Perhaps the AreaGapAndOverlapCleaner and/or the AreaAmalgamator would be worth trying here.
albinepro
  • Jun 9, 2023 2:52 PM UTC
I just gave it a quick shot. AreaAmalgamator dissolves the boundaries, I need to preserve the rooms (polygons) boundaries. But I haven't a clue about this transformer, good to know. AreaGapAndOverlapCleaner could be an alternative for cleaning once I use the Bufferer instead of calculating threshold on shapeform ratio, overlaying areas and dissolving slivers. Thanks for suggestions.
