ShortestPathFinder doesn't work
  • Mar 16, 2022 3:21 PM UTC
  • 72 views
marionmahot
Forum|alt.badge.img+4
Hello,
I have a shape with points and a shape line. I want to create the shortest path between my points which have the same trip_id with the stop_seque field but the shortestPathFinder doesn't work.
I don't understand ?
Please do you know what is a problem ?
Thank you
owen
  • Mar 16, 2022 3:39 PM UTC
Hello, you will need to build a line input into the shortestpathfinder by connecting the points. Also it helps if you split the network where your points are with a PointOnLineOverlayer
marionmahot
  • Mar 17, 2022 7:49 AM UTC
Hello,
I create a topolgy builder before and i put my lines in the input ports Network and points in the From-to but i don't understand why it's necessary to have the transformer PointOnLineOverlayer ?
Thank you
owen
  • Mar 17, 2022 9:41 AM UTC
Hello,
Thank you
The shortestpathfinder needs a line input for the from to, not points
