SharePoint online connector transformer special character in filename error (#)
  • Jan 9, 2023 5:11 AM UTC
  • 120 views
badgerseatfrog1
It seems that any file with a # in the filename won't download when using the SharePoint online connector transformer. I want to download using the _fullpath method.
Simply --> if the filename is FOO_1 it works. If it's FOO#1 it doesn't.
The rejection code is SHAREPOINT_ERROR , the URL it's trying to DL is:
SharepointOnlineConnector: Error making request to https://graph.microsoft.com/v1.0//sites/ac[HIDDEN]%20November%20#4.jpg: The resource could not be found.
Is there any way to get around this? I have tried the URL ENCODER and STRING REPLACER transformers to try and manually encode the # symbol but it doesn't like this. Presumably because it's trying to encode it "again"workbench_error
I can tell my users to stop using a # symbol in the filename but would rather solve it more elegantly and retain the original name.
Link to transformer:
https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_Transformers/Transformers/sharepointonlineconnector-pkg.htm
nielsgerrits
Forum|alt.badge.img+67
Not sure if a quick fix exist for this but as this is a transformer from the FME Hub it technically can be updated without having to wait for a new release. I would submit a case to be sure to get the attention from Safe, maybe add a comment on the specific FME Hub page.
danminneyatsaf
Forum|alt.badge.img+13
@badgerseatfrog1​ thanks for bringing this to our attention. After reproducing the issue, it looks like this is a bug with the SharePointOnlineConnector. Since this transformer is handled by our developers, I created a bug report to get the issue fixed. For your reference, the issue number is FMEENGINE-76020. We will post here when the bug is resolved, thanks for your understanding!
badgerseatfrog1
no worries, thanks @danminneyatsaf​
donalmateer
Happy to share with the community that this issue has now been resolved 🎉
This issue should now be fixed in our latest SharePoint Online package [1.13.3]. This package requires an FME Build 25630 or higher.
If you are using build 25630 or higher, you can go to FME Options -> FME Packages -> SharePoint Online -> Check for Updates -> Update to install the latest version of the SharePoint package.
[Internal Note: FMEENGINE-79388]
Happy FME-ing!
