SFTP Login failure in the last month
  • Sep 2, 2022 9:06 PM UTC
  • 85 views
I've recently been getting an SFTP login failure when running my FME workspace.
This was working back in July, but is now throwing the following errors:
FTP info:  Trying 'SFTP IP ADDRESS'...
FTP info: Connected to SERVERNAME ('SFTP IP ADDRESS') port 22 (#0)
FTP info: SSH MD5 fingerprint: 'FINGERPRINT'
FTP info: SSH authentication methods available: publickey,gssapi-with-mic,keyboard-interactive,password
FTP info: Failure requesting identities to agent
FTP info: Authentication failure
FTP info: Closing connection 0
FTP/FTPS/SFTP transfer error: Login denied
Now, this I can still connect via my same SSH key using an FTP tool such as WinSCP no problem.
I'm loading the private key via a SystemCaller and the following command beforehand:
Start cmd /c "C:/Program Files/PuTTY/pageant.exe" C:\\PrivateKeys\\PrivateKey.ppk
matthieuv
Forum|alt.badge.img+30
  • Sep 15, 2022 10:20 AM UTC
Do you have access to the log of the FTP server?
Hi, I do not have access to the FTP server logs.
However, I did notice as of yesterday that the connection seems to be working again.
I have no idea what changed to allow this, as I haven't made any changes to the FME workspace since this has come up.
It's possible it is related to the FTP server instead.
